wich asio surce/dest.
starcorp
Post by starcorp »
acording to no answers in the xtc tread, i try it here.
i have tried the asio modules in my xite project. but i cant see any vst connections in nuendo 4.
shure i have chose the xite asio driver for nuendo.
wich asio surce/dest. did you using?
regards! jan
Re: wich asio surce/dest.
did you go to vst connections and enable your i/o in Nuendo?
also, you must have the asio modules in the routing window with the proper number of channels BEFORE opening Nuendo...
starcorp
Post by starcorp »
thanks for the answer.
yes, i did that before starting the sequencer. and the problem is, ive tried all kinds of asio moduls with no success.
no vst conections showing up in nuendo.
regards. jan
then you must not have "ASIOScope" selected as the driver in the asio multimedia settings...
almost all asio modules work with Nuendo, for sure.
you must have proper pairs, i.e. ASIO2 24bit source with ASIO2 dest or ASIO 16bit source with ASIO 16bit dest or ASIO2 Flt 64 with ASIO2 64 dest....
starcorp
Post by starcorp »
i select scope asio in nuendo of course.
but i solved my problem.
i build my squencer projekt not from zero these time.
i began form the start projekt. and asio modules works now.
regards. jan
