SCOPE 5- Cannot start the SCOPE application error code 0001
I finally got my keys this morning but after installation and importing the keyfile I get:
"Cannot start the SCOPE application! (error code 0001)"
The drivers selected are the new ones and in the startup registry I changed from 4.5 to 5.
is there an errorcode descripion list?
cannot find it in the manual.
Re: SCOPE 5- Cannot start the SCOPE application error code 0001
Same problem here...
..like i just explane in:
http://forums.planetz.com/viewtopic.php ... &start=120
sounds like the wrong driver....
as mentioned before (see other thread above) we tried to manually exchange the driver. the correct driver version is definitely loaded.
I tried the following:
- uninstall v5
- switch to old drivers to make the v4.5 uninstaller work again
- reboot to make the v4.5 uninstaller work again
- uninstall v4.5
- uninstall drivers
- reboot
- install v5
- reboot
- install new drivers
- reboot
again: error 0001
- uninstall v5
- uninstall v4.5
- uninstall drivers
- reboot
- install v5
- reboot
- reboot
again: error 0001
turn off the machine.
remove the card.
boot.
install the card.
install the new driver.
install the software.
i hope that helps...
not being there, it's pretty hard to do more than guess, with the info i have...
remove the card.
boot.
install the card.
just received an email from sc -> I will get a new keyfile
so, this error 0001 was connected with keyfile ?
i have tried some time ago and i get the same error window,
also recieved email now and waiting for new keys,
hope it works then,
matej
hope it works then,
matej
yeah! new keys work!
YES !!!
here too, nice,
let the show begin
here too, nice,
let the show begin
Yes,. problem solved,.
Ralf mailed me a new keyfile,.
no, that was not me, it was the server.
Currently i get a lot of emails with hardwareserialnumbers, without hardwareserialnumbers . . .
To get the Scope 5.0 keys, please send an email with your actually keyfile attached to register@soniccore.de
That's the way !
Ralf
That's the way !
Ralf
Rinse wrote:Yes,. problem solved,.
I've got lots of software serial numbers (DAS, Flexor 3, XOR ...),manually typed, which doesn't work with Scope 5 ?
any advice ?
thanks,
matej
any advice ?
thanks,
matej
- next to nothing
If you check your <scope 4 directory>/App/Bin and open the "scope.rgy" file, the devices should be regged there. That file should contain your extra devices with serials...
Well I actually did that exactly,.
Just emailed the scope.rgy file.
I have recieved another key this afternoon but cannot check if it fixes this right now,. but reading the other posts I believe it's ok.
nah, i know what was wrong,
i wrongly send first email with allkeys.sfk and then when i see that i send another email with scope.rgy ,
but i've recieved keys for Scope 5, which were in allkeys.sfk (which is old) and not for scope.rgy,
so i re-sended email now.
Matej
Matej
Problem solved here with new keyfile
Now must try new device and SC-Plate is the first
yeah!!
- Mr Arkadin
Ah, that's quite important to know, as in the past just the hardware number was needed. i need to resend my request now.Ralf wrote:
That's the way !
Ralf
well, strange is , that i can't run Optimaster, but i have key registered for Optimaster , i even see it under Scope 5 - registry window, but can't run it,
i can see registration window all the time, whatever i do
Matej
Matej
here:
when i click on import and choose key file , it says "import ok" , but registration window appears again...
- optimaster.JPG (58.55 KiB) Viewed 4957 times
