Is there such a device in the SDK?
I am anxiously waiting for the postman to bring me the SDK paperwork from Ralf...
in the meantime -
I want to take the beat frequency between 2 oscillators (at low frequency), feed through a Schmidt trigger to trigger an envelope. Can it be done or is the Schmidt trigger redundant?
Eric.
Schmidt trigger
Schmidt trigger
Your mouse has moved. Windows must be restarted for these settings to take effect.
Eric Northwood - Data Recovery Specialist
Re: Schmidt trigger
all that is is a gate which is triggered at a higher level than it releases, (it has hysteresis)
are you trying to have the beat frequency actually turn the envelope on and off? why would you do that
Re: Schmidt trigger
Yes I want to turn the envelope on and off with the resulting square wave produced by the Schmidt trigger. The beat from the 2 oscs would pass through a low-pass filter then be squared up by the Schmidt. Does an envelope generator require fast leading/trailing edges or could you feed it the waveform from the low-pass filter and let it trigger when the level is high/low enough? (In an electronic circuit, this wouldn't be repeatable or predictable enough.) In emulation maybe you can't connect an audio source to a trigger destination.Neutron wrote:all that is is a gate which is triggered at a higher level than it releases, (it has hysteresis)
As for why - why not?
Eric.
Re: Schmidt trigger
you have to change the resulting signal to a "gate" i believe it would work without anything else, that stuff usually works on zero crossing.
or you can just use an envelope follower set to very fast attack and decay, on a low enough frequency it will just turn on and off and you can adjust the threshold.
Re: Schmidt trigger
Thanks.
I guess it will all become clear when SDK arrives.
Eric.
Eric.
