Gate delay for double envelopes
johndunn
Post by johndunn »
Is there a relatively dsp-inexpensive way to get a gate delay, to create DADSR envelopes, envelopes that trigger some time after receiving the gate signal...and still keep polyphony? It seems this would be simple to make, a gate in, a countdown timer, and a gate out. But none appear on either Modular III or Flexor, as far as I can see.
Shroomz~>
Re: Gate delay for double envelopes
Post by Shroomz~> »
Hi John,
edit - updated zip with 2 poly gate modules sharc made in BC Modular format - a Gate Delay & a Gate Inverter.
2newBCM_GateModules.zip
(54.91 KiB) Downloaded 201 times
johndunn
Post by johndunn »
Cool. I'll check them out and report back. Many thanks!
-jd
Algorithmic Arts
http://algoart.com
johndunn
Post by johndunn »
Don't think it does poly. I'll send the details via PM.
-jd
Algorithmic Arts
http://algoart.com
Shroomz~>
Post by Shroomz~> »
I sent you a PM & have updated the zip I posted above with 2 poly gate modules that sharc made in BC Modular format - a Gate Delay & a Gate Inverter.
Shroomz~>
Post by Shroomz~> »
Some of you might need this attached dsp file.
GateDelayPolyDsp.zip
(3.97 KiB) Downloaded 184 times
