B2003 AND NOVATION W/ SPACEF CC2 x 2 ( x2 ) for YaYaJohn
The B2003 will remember the drawbar settings only in SFP 4.5.
You will need to re assign the Rotary speed manually on start up every time.
Fortunately the developers at SC read these forums and have corrected this in SFP 5.0 which will be released soon.. :roll: , along w/ many suggestions in regards to 3D/transparent modules in the project window, etc.
We should definately Skype when you start this. Here's the devices from SpaceF.
http://www.spacef-devices.com/dacore/in ... info&id=59
I had no room for the B2003 preset. I will add it once you respond to this weak attempt to explain the use of these beasts.
You must type in the values of each CC in the SpaceF devices.
netguyjoel
Re: B2003 AND NOVATION W/ SPACEF CC2 x 2 ( x2 ) for YaYaJohn
Post by netguyjoel »
And the caveman's name is Joel...
Joel
Wow, I actually think I can do this. Thanks for the detailed step by step jimmy. I'll hook everything up and try it tonight.
And thanks to spacef for that free device and John Cooper for this most awesome site :)
Dan
