can pulsr 1 work in more then 16 beat?
doodoo52
Post by doodoo52 »
i have pulsr 1 . can i work in 24 beat or more then 16 beat ?and if i can .from were i can chenge the beat in the card?
Re: can pulsr 1 work in more then 16 beat?
16 or 24 bit?
yes. the setting is made by choosing 16 or 24(or 32 or 32bit float) software i/o modules.
doodoo52
Post by doodoo52 »
do i nead for 24 beat a 24 mixer?or i can use the 16 beat mixer.ther is not a 24 mixer in my softwere.
the mixers are at least 32bit. no, it doesn't matter. bit depth compatability only matters to the point of what the AD/DA converters and recording software are dealing with. bit depth does not work like samplerate.
doodoo52
Post by doodoo52 »
so if i understend you i can work with the 16-32 mixer and from i\o to bring the 24 beat wave dest. and wave source and the asio 24 beat and source.and i will have the best beat thet the card can give.
by the way what is the most beat the pulsr 1 card have?
alfonso
Post by alfonso »
1632 means it is a mixer with 16 mono or stereo(32=16x2) channels. All the environment is always 32 bits. The converters are 24bits. The format of the file that is recorded to a sequencer or other recording software is determined by the choice of the ASIO (16, 24, 32 bits) or Wave (16, 24 bits) drivers.
