SPINNER (4-mode filter pan mod FX) - UPDATED 31/03/09
Shroomz~>
Post by Shroomz~> »
SPINNER is a FAT 24dB multimode resonant filter with Low Pass, High Pass, Band Pass & Notch modes
Frequency range - 20 Hz to 20 kHz
Modulation frequency range 0.1 Hz to 1.0 Hz
Spread parameter - 0 to max (spreads frequency of poles 3&4 away from poles 1&2)
Let me know what you think & if you find any issues or problems.
~Mark
SPINNER.zip
Updated on 31/03/09 - Presets now load with device. Added WET/DRY mix, altered max resonance & updated GUI.
(604.41 KiB) Downloaded 1513 times
SPINNER_DEF1_presets.zip
(1.48 KiB) Downloaded 1376 times
image is 80% scale.
image is 80% scale.
Updated on 28/03/09
- fixed a couple of things that I'd forgotten about & added preset capability.
29/03/09 - Added a set of 58 Default presets. Download the 'SPINNER_DEF1_presets.zip' file & extract it to your Scope presets folder.
Updated on 29/03/09
- Fixed filter type switching issue. Now it works properly.
Updated on 31/03/09
the19thbear
Re: SPINNER - 24dB multimode filter panning mod effect 27/03/09
Post by the19thbear »
once again shroomz! if i had a hat, i would take it off right now!
looks great! reminds me of the filter on the new minimoogs, with the stereo spread!
cant wait to use it!!! ( havent used it yet though..)
Mr Arkadin
Post by Mr Arkadin »
Great stuff. The only initial niggles are that when i right-click to open the presets list i get the presets for XTreme Cut Pro. Also (v. minor) i find it distracting that the Type LED flickers as well as changing the other LEDs - not a biggy that one :lol:.
It's my new Leslie Emu.
I got 3 of these FAT BASTARDS trying to doppler.
It would need the faster rate altered but the controls are all there.
It has the XTreme's panning feature that I thought was wicked.
01-090328_1517.mp3
Thanks Shroomz this is a much better way to get full sounds w/o coloring or cutting as an EQ would do.
Filters are the shit.
I am trying to do the rare and old Psychedelic Leslie that was 3 x 15 inch woofers spinning w/ Black Lights and colors. I band for each speaker......Coolness.
Shroomz~>
Post by Shroomz~> »
Mr Arkadin wrote:Great stuff. The only initial niggles are that when i right-click to open the presets list i get the presets for XTreme Cut Pro. Also (v. minor) i find it distracting that the Type LED flickers as well as changing the other LEDs - not a biggy that one :lol:.
Hi Mr. A,
It's not Xtreme Cut Pro under the hood FWiW (but I see that Jimmy V already sussed that out from his post. :cool: ).
The short explanation is that I now use Xtreme Cut as a shell/starting point for stereo insert effects because it has everything I need in there, such as required midi modules & also has Scope remembering midi CC assignments on project save/reload. I just forgot to delete the preset list from the empty shell.. I'll fix that & upload a new version with any other issues fixed as well. Man, I need to remember to save it as my new empty insert effect module this time... doh!
~Mark
(been away from sdk for too long) :wink:
Shroomz~>
Post by Shroomz~> »
XITE-1/4LIVE wrote:It's my new Leslie Emu.
Many thanks to you JV for the inspiration. If it wasn't for your feedback about panning modulation possibilities on Xtreme Cut, this device wouldn't have happened so soon.
Faster rate, eh?
You Betcha,
You know the days of pretty jpeg's of ancient mixers and synths is so passé.
Devices like this that hardware cannot do are the future IMHO.
Solaris will be setting the pace in hardware, and bright developers for Scope will do the software........ankyuvarymush... :wink:
Shroomz~>
Post by Shroomz~> »
Updated on 28/03/09
~Mark
Shroomz~>
Re: SPINNER -24dB 4mode filter panning mod FX - updated 28/03/09
Post by Shroomz~> »
If you're one of the few people who downloaded the new version today, please download it again. I uploaded the wrong file earlier.
~Mark
Ankyu.......
Now it's gone like a " Fart In The Wind. "
I downloaded one that was about 80k larger.......
I'll check back later...........I also need some sleep.... :lol:
Mr Arkadin
Shroomz~> wrote:If you're one of the few people who downloaded the new version today, please download it again. I uploaded the wrong file earlier.
~Mark
...er, where's the new file? :D
nightscope
Post by nightscope »
Thanks for this whateveritis, Mark. If it makes things go round and round it'll do nicely. Your efforts are appreciated.
ns
Shroomz~>
Post by Shroomz~> »
Guys, it's in the first post of the thread. :cool:
ns, well it 'sort of' makes things go round & round, but it wasn't designed as a rotating speaker effect or anything like that. It's not a panner either despite it having a panning sensation. It's simply frequency dependent delay applied to one side's LFO modulation. ... try it out & let me know what you think.
~Mark
igge1
Post by igge1 »
Mmmm, looks good and sounds good. Excelllent. 8)
zangsta
Post by zangsta »
Thanks, Shroomz, another good one ! :D
Useful for this and that...tried it as modulator for guitar.
It will be a useful tool !
Zangsta
Shroomz~>
Post by Shroomz~> »
Coolness Zangsta! I chucked a few tracks through it for quick demos, but some guitar would be nice! :D
These are just plain Lazy, but you can hear what the effect does pretty well. I think it could have some usefulness here. :D
nightscope
Shroomz~> wrote:... try it out & let me know what you think.
Just given it a spin.
Excellenté, as Rigsby might have said. I shall lash up the knobs and buttons to the Bitstream forthwith. This thing goes from very subtle to decidedly seasick. Rather useful gizmo. Gracias.
ns
iSiStOy
Post by iSiStOy »
tantalising.
Many thanks Shroomz!
Fluxpod
Post by Fluxpod »
Thanks.Sounds nice.Very usefull device! :)
Shroomz~>
Post by Shroomz~> »
I've added a set of 58 Default presets. Download the 'SPINNER_DEF1_presets.zip' file & extract it to your Scope presets folder.
These default presets are only using the LPF. I concentrated on setting up a useful set of modulation frequencies. :wink:
~Mark
