Audio from cubase VST to ableton live
darkbear
Post by darkbear »
Hello guys...I am planning to transfer my cubase Vst 5.1 (here is the vintage guy) songs (audio+midi) to ableton live...more than 200 songs....A lot of job...The "classical solution" will be to create midi file (in wich format?)and to export audio tracks...It's not so easy because when you export audio tracks one by one you loose all time reference... So you have to create a big audio part , with silence sometimes, beginning at the start of the song in order to synchronize all the tracks....Big job....An the cubase vst audio pool is a real nightmare...Using this way you can easily loose files. BUT...using the tremendous routing of scope maybe there a solution: the casual asio drivers for cubase vst, (with all my treatments within the 2448) and record audio in ableton using 24 bit wave drivers (does it's possible to use wave drivers with ableton?)...For the midi , it's not a big deal with all the midi sequencer
in/out available...Any advices, tricks and / or experiences about this kind of process are welcome...Or maybe radical new idea to do the job....Thanks...
Re: Audio from cubase VST to ableton live
When doing stuff commercially, transferring between applications usually uses some common exchange file format (omf etc) that works well between the packages in question. Even with these interchage formats you quickly find that each program's implementation of the file formats leads to a 'learning curve' when exchanging files between applications. Meaning even with universal interchange standards you must learn how to prepare what you're exporting, what options to set, what metadata to tag with, how to name clips, files and etc. So basically even with a direct 'built in' migration path it's a process of trial and error to get things to transfer reliably.
This doesn't directly apply to Cubase 5.1 > Live I don't think since I'm fairly sure Ableton Live doesn't support much for importing (beyond raw tracks you have figured), but the idea is still relevant here. Ie, you're going to have to pick a few projects and experiment to get the process down. You already have a basic idea of what you need, the midi structure & audio structure should all line up through the export>import process, and most plugin settings will have to be tested to see if they will work (via fxp/fxb). Now I can't comment directly on what you'll encounter with Cubase as I can't remember 5.1 much these days, but I can help with some hints on what might help for the audio & midi tracks:
For the MIDI bits, pick a common point at the start where there isn't *anything* and insert a single note & controller value on midi tracks to 'initalize' the starting point. That means you'll have to pad the beginning of your song with some meaningful interval (16 bars, 32bars, 8 bars or whatever u deem necessary) for ableton's sake. Quantize these bits of midi information it to exactly the start of that bar. For extra credit any external gear can have sysex data recorded or cc values initialized after this point in its own track, assuming there is any (this was a common thing to do in the 'old days' during any tune's "preroll" or "lead-in" to get a device's settings dialed in).
For the audio you have several considerations as well, the first being your start point. The easiest thing to do here is to draw a waveform by hand or create it somewhere, I would suggest something like a saw wav, long enough to be visible from a decent zoom, ie, a single cycle from 0 to close to full volume (vertical line) that decends back down:
example done in Cubase SX: http://www.kief.net/studio/exporting_wi ... points.jpg
Any serious level changes versus the raw audio may need to be applied to the track or you'll need the ability to do extensive comparing of your mixing automation once in Ableton to achieve the same balance. This also brings another point up, should existing eq & effects be applied or not? You have the option of with effects, without, and even better choosing some combination thereof. For instance you might mix several sections to completed 'stems' for easy remixing, then each track can be provided 'dry' and 'wet' with everything applied (and then should the 'dry' track be sans everything including volume or not?). It's entirely up to how robust you want your options to be later on...
After some thinking & experimenting with those options, you'll also have to figure out a meaningful naming convention for what you're rendering out so that things make sense on bringing the data back into Ableton. You might also want to experiment with 24bit and 32bit file formats to see what you're happiest with there (I think both applications support 32bit int & flt file formats, but not sure about Cubase 100%).
expoert each track as a wav, and then just import the tracks into the new app. it's simple and all tracks will start at zero, so they will all be aligned. of course, you won't save mixer or plugin settings, but so what. why transfer to another program to save the exact same mix?
