Hi guys I'm really interested in these type of plugins for Scope and VST.
I was just wondering what you guys use.
I would like a nice tempo delay/echo device that pitches the delays and a
good step sequenced delay which is tempo based and controlled by an LFO etc.
Best delay/ Echo with Pitcher plugin and Step sequenced gate
Music Manic
Re: Best delay/ Echo with Pitcher plugin and Step sequenced gate
LBH VIII is a vast Instrument capable of all that and much more.
http://www.spacef-devices.com
I bought it when it first came out but only listened to Mehdi's tricks and demos it comes with.
Get a free demo from the site w/ a timer on it, but you'll need at least a couple days just to see the instreuments effects and routings.
The sequencer is a first for SFP as far as depth goes.
I will be playing with this for an hour or so everyday until I figure out what I want to use it for.
- the19thbear
there is d trip-- thats a free delay. search for it here on planetz.
It has an LFO that can modulate the delays.. and it actually sounds alot like an analog delay.
- next to nothing
SpaceF Echo 35
Part of the Blackbox II (FX). One of the better value for money device packages for Scope.
http://www.spacef-devices.com/dacore/in ... &Itemid=27
that's kind of a vast understatement
Echo 35 is top notch
you probably can feed some step sequenced control signal into it, but I never tried as it's already stuffed with modulation possibilities.
You can even insert it into the feedback path of itself
for the more traditional tape stuff Celmo's TapeEchoSim is worth checking
