Anyone know of a device for switching between monitors?
sodiumcycle
I'm looking for something to quickly switch between three stereo outputs. Anyone know of such a device?
- garyb
- Moderator
Re: Anyone know of a device for switching between monitors?
radio shack used to make a cheap one, dbx used to make a good one in the 80's and before...most real studios just make a switcher. don't those control room devices like the mackie big knob do that? you could do it from within Scope as well.
sodiumcycle
A scope device would be ideal: Stereo in with a 3 way switch for 3 Stereo out.garyb wrote:radio shack used to make a cheap one, dbx used to make a good one in the 80's and before...most real studios just make a switcher. don't those control room devices like the mackie big knob do that? you could do it from within Scope as well.
- garyb
- Moderator
you should talk with the SDK guys, although i'll bet one's been made, and i'll bet modular can do it...
*edit* i think SpaceF made a switcher. maybe a small donation would set you up.
MD69
Am I wrong, but isn't control room able to do it?
- Shroomz~>
I'm sure there's various options, but here's a simple stereo 1>3 switch that you can use for various things. You can also control it via midi.
~Mark
~Mark
sodiumcycle
Thanks Mark! This is perfect.Shroomz~> wrote:I'm sure there's various options, but here's a simple stereo 1>3 switch that you can use for various things. You can also control it via midi.
~Mark
