SPACE EQ - simple Stereo EQ device for mixing & mastering
Shroomz~>
Post by Shroomz~> »
Hi all,
I'm pleased to give you my first new Scope device creation in over 5 months - SPACE EQ. It's a very simple stereo-only device that combines EQs based on on Creamware's excellent 2-band parametric with a spacial technique which doesn't involve delay or reverberation. The spacial effect can be turned off simply by turning the 'SPACE' parameter fully left. There's also a softclip at the output stage which can be switched on & off.
The Low & High frequency EQ parameters all use stepped potentiometers for ease of making very quick settings. The EQ values & ranges have been set up with the sole idea in mind that the device can be used for mixing & mastering purposes (probably with no or very little use of the SPACE parameter, which is a special effect for those who like to dabble with experimental mixing techniques). I made SPACE EQ for my own mixing knowing that I will sometimes wish to mix with 3 or 4 dB boosts at 60-80Hz & 8-16kHz.
Feel free to let me know what you think..
SPACE EQ.zip
SPACE EQ
(585.74 KiB) Downloaded 2232 times
Have fun folks.. :cool:
~Mark
RecS
Re: SPACE EQ - simple Stereo EQ device for mixing & mastering
Post by RecS »
:o :o :o :o :o :o :o
Thenks Shroomz
Is it a gift on March, 8? :wink:
Accepted!!! :)
This device actually sounds like the different mic positions that so many guys rave about on the romplers.
The Space knob fully left, 12 o'clock, then fully right gives me 3 " mic " positions on my fake Grands.
These developers actually have everybody Buffalo'd into thinking they actually re recorded 12 different mic positions, with different 4000 dollar mics, etc.
And here comes a DSP device that even sounds cleaner... :lol:
Nice Job Shroomz, Thanks.
devastate
Post by devastate »
cheers Mark,
I look forward to this as your previous stuff is all top notch. Will have a blast this evening after this paperwork is done :( .
Jah Servant
Post by Jah Servant »
nice one, but the eq doesn't seem to be working at least I'm not hearing any difference from -4 to 4 on the high or low. The gui is sweet, as always.
next to nothing
Post by next to nothing »
It works, Jah.... Its very subtle, but it works. Chances you will hear any changes are of course bigger at 8 than at 16. way i testetd it was to have a long sustained sawtooth chord from minimax, then juggeling the gain dial.
Jah Servant
ok cool, I was just trying it during a session actually so :D
Shroomz~>
Post by Shroomz~> »
Jah, I might make a special version with x2 & x3 multipliers for the gain parameters, so that the gain can be switched from +/- 1,2,3,4 to 2,4,6,8 & 3,6,9,12 dB. I should maybe have done that anyway, but I wanted to keep it subtle, so that the myself & any other user is limited & can't over-use EQ. Anyway, it won't be for a few days because it involves some extra graphics work for paging the gain surrounds, but I'm busy with other projects at the moment.
~M
I am glad to hear you are busy........ :wink:
devastate
Post by devastate »
loving this Mark,
put some full mixdowns (unmastered) through it and it gave them a lovely sound, I deliberately chose some boxy middy stuff and with settings around the +3 at 60hz and 16khz with 3 quarter drive and a tidgeon of space, they sounded mastered without any limiting or multibanding. Beautiful.
I loved the fact that as the settings are subtle you can screw the hell out of the dials without wondering if you've gone too far.
cheers
Dave
Shroomz~>
Post by Shroomz~> »
Thanks Dave. I'm really pleased to hear that someone's tried it in that sort of situation & liked the result. When I was using it the other day I was thinking of a way to improve it, but I don't have time at the moment.
zangsta
Post by zangsta »
I finally got some time to check this one out.
And, Shroomz, this was a pleasant surprise ! :o
It´s a great tool for a guy like me with plenty of old recordings to
some day bring up to a better standard, thanks a lot !! :D
Zangsta
zangsta
Post by zangsta »
Space EQ is simply brilliant...!
Now I think it´s just as indispensible and useful as Tony Chacheres Creole Seasoning!! :o
It can be used on everything ! :lol:
I have it last in chain after Knottsbox V & FX, and it´s great !
Thanks for giving us all this great stuff for free.. :D
Cheers
Zangsta
Mydriasis
Post by Mydriasis »
This EQ is really special.
I love the way it enhances stereo on higher frequencies and those eq settings are ideal for adding depth to computer made music.
As a UAD user im amazed at the amount of quality free devices for Scope.. If UA made this it would be at least $200
Shroomz~>
Post by Shroomz~> »
Thanks man!
Another user.... that makes 7!! :D
zangsta
Post by zangsta »
Shroomz~> wrote:Thanks man!
Aaa..no no no no..don´t be so negative..downloaded 553 times !! :o
And me, I use it like in almost every project.. :D
Good work there, Shroomz ! :)
ARCADIOS
Post by ARCADIOS »
Super musical feeling!!! You made it so simple choosing the most musical frequencies+the stereo depth controls....
REALLY GREAT!!!
So delicate quality Mastering tool !!!
I TEST IT WITH STUDIO MONITORS AS GENELECS 1032A... SOUNDS GREAT
faxinadu
Post by faxinadu »
only now grabbed this, very good thanks!
http://www.oceanswift.net
Music
Yogimeister
Post by Yogimeister »
I have recently started exploring this device and loving it on the master bus.
(I usually put around 1/3 distortion and a small touch of space - and depending on the material - a light smiley eq, or frown with high q ... Or no eq ...
But I really like the Thickness it adds !
Lovely !
