I have a problem with the recording timing of the midi signal in cubase sx 3. the signal reach the sequenzer in time but it will be recorded with a high latence. i checked everything, my routing windows, the samplerate settings of the card and cubase, the settings of cubase, asio-settings, really everything but i dont find the mistake!!!!what could it be??
i would appreciate help!!!
thanks in advance.
Midi Recording problem with Cubase Sx3 & Scope Home 4.5
Re: Midi Recording problem with Cubase Sx3 & Scope Home 4.5
Hi!
Perhaps you can check "use timestamp" in Cubase (Devices > Midi.....)
Ive had this problem before, and this solved it for me
thank you for the tip but where in the settings can i find "use timestamp" exactly??
Jah Servant
did you find it? it's in your Device Setup, under the Devices menu, then in midi port setup, check the timestamp boxes
Or maybe the midi resolution ticks in preference.
Christian
Christian
