i have a ovation 30th anniversary guitar. problem is the 1st string is loud than others. do you have any clue how to solve? or is there other forum you know where can i get help.
thanks
sort of guitar pickup problem
Re: sort of guitar pickup problem
Ovation! Cool!
It seems that the 1st string is newer than other strings! Isn't it?
Just Play it in couple of days!
Long
Long
nice one LHong...
if they're all the same age, you probably need to replace the bridge/pickup(one unit). you'll need to get the guitar set up when it gets changed. those ovation pickups go bad all the time...
http://www.mypicx.com/02232009/ovtion_peizo_pickup/
is this the peizo pickup? where can i buy this stuff?
thanks
thanks
it's an assembly. it's the bridge. if you pull the bridge up, there's a wire attached. as you can see in the exploded view, the peizo is sandwiched inside the bridge. you can get one from ovation(kaman), or a service center.
