Using xtc mode (basic). thanks
I have a scope 15dsp pci card (with the ADAT inteface) and i would like to get your help for using it.
I have failed to get it to work the way i wanted with the manual.
I also have another audio interface for recording with digital and analog ins\outs which works with ASIO.
I understand there are two modes to get the scope it to work:
1. regular mode
2. xtc mode
both modes only works for me when i use the scope asio driver (when i do that i cant use my second card).
I only want to use the scope card for its plugins and no for recording. what can i do to get them both to work?
Thanks for your help.
1. regular mode
2. xtc mode
Re: Using xtc mode (basic). thanks
put it in an external box - connect via Midi and Adat (I hope the other card has some...)
A Pentium 3 with Win98 is all that's needed, you can run it from compact flash.
Thank for the quick replay.
Are you sure thats the only way? there is no way around?
BDW i have adat in both of them but i have never used it.
Does a normal optical cable link them properly or do i need a special cable for it?
Thanks again.
Thanks again.
I am afraid not.You cant use more then 1 asio driver on a pc.A second pc for scope is ime a good solution,i am having a second pc for 3 cards and connected via adat/midi.
OK ,i mean, i hate creamware now but thats what i should do
can someone please answer:
i have adat in both soundcards but i have never used it.
Thanks again.
Thanks again.
No reason to hate creamwaremajistik wrote:OK ,i mean, i hate creamware now but thats what i should do![]()
Thanks again.
If you want to connect 2 cards in and out you just need 2 standart optical cables for 8 channel i/o or 4 cables for 16 channel i/o.
You need to define the Master device.Set scope to slave and the other card to master(wordclock).Thats all you need to do and you are running.
UAD would never do it to meFluxpod wrote:No reason to hate creamwaremajistik wrote:OK ,i mean, i hate creamware now but thats what i should do![]()
Thanks again.Its that way with every card.
anyway, Great. thanks
You can also take a look at this thread: http://forums.planetz.com/viewtopic.php ... &sk=t&sd=a
Wow ok! I wasnt aware of that.Pretty cool thanks for the info tau!Tau wrote:You can also take a look at this thread: http://forums.planetz.com/viewtopic.php ... &sk=t&sd=a
No problem! I never tried this myself, as when I first read this, I had already set up a 2nd DAW for Scope. But if it does work, then it should be the "missing link" for XTC and 3rd party audiocards. If you find it works properly... spread the wordFluxpod wrote:Wow ok! I wasnt aware of that.Pretty cool thanks for the info tau!Tau wrote:You can also take a look at this thread: http://forums.planetz.com/viewtopic.php ... &sk=t&sd=a
T
Looks cool but i have no knowladge about electricity :S I will ask a friend to help me and tell you if that works!Tau wrote:You can also take a look at this thread: http://forums.planetz.com/viewtopic.php ... &sk=t&sd=a
WORKING !!!!!!!!!!!!!!!!!!
Great! Good to hear man!
