DP35DP and audio drop-outs
gustav
Post by gustav »
Hello
I updated my system to dp35dp + e8500 on win xp pro, scope45 and sx3
pulsar2 & srb
I encountered dropouts when moving the mouse so I made a minimal installation :
win xp
drivers intel dp35dp (last ones)
driver video carte matrox perhelia (last ones)
pulsar2 alone on one irq (I did not install the SRB)
sx3
scope45
the same problem occurs : drop outs when moving the mous, even sometimes without moving
is the order of install correct - i allways did it like this
may be its about latence pci bios = 32 or hyperthreading ?
Can somebody try to help me ?
next to nothing
Re: DP35DP and audio drop-outs
Post by next to nothing »
Try switching USB port for your mouse.
yes, move the mouse to a different port and disable the usb controller that shares an irq with the scope card in the device manager.
gustav
Post by gustav »
Hi I tried other ports for the mouse but allways the same problem.
start/programs/accessories/system tools/system information/hardware resources/conflicts-sharing...
what is sharing an irq with the Scope card?
gustav
Post by gustav »
this is the installation with pulsar2 and srb :
http://hurpasard.free.fr/conflicts_sharing.txt
the pulsar2 is all alone on his irq - no desactivating necessary.
the srb was not alone - but I desactivated 2 usb controlers, pci express root port3 and smbus - so now its alone.
does it work?
kwild
Post by kwild »
I think it's DPC latency issue.
All old BIOS of the Gigabyte P35 series mobos have CPU spikes that causes stuttering,clicks & pops.
Use that tool to see if u got that CPU spikes :
http://www.softpedia.com/get/System/Sys ... cker.shtml
If u wanna some more ifoz about that problem and gigabyte mobos :
http://forums.steampowered.com/forums/s ... p?t=681108
Try another bios to solve the problem.If u don't solve nothing,contact Janus from the GIgabyte support : janus.yeh@gigabyte.com.tw
After some days i got a new beta bios (not available on the official site) that solve the problem with my Gigabyte GA-P35-S3G.
Another thing that you must try is to disable all network cards/adapters (modem/wifi/ethernet).
kwild
Post by kwild »
Maybe that topic on TweakTown forums can be useful :
http://forums.tweaktown.com/f69/p35-mot ... ing-26456/
______________________________
Mobile Suit ERA / Nu*ragika Recordz
http://myspace.com/mixmasterservice
http://myspace.com/_kwild
http://myspace.com/balentia
gustav
Post by gustav »
garyb wrote:does it work?
Sorry about my errors when writing english - what I tried to say is that after my first test and post hear on planetz I made sure that the irq is not shared - so I'm said to say that there is nothing new to report.
After so much time spent on the new system without making music I invited a friend to record some noise together, it was fun and its pretty clear that the dropouts come when mouse moves.
Kwild, My mobo is INTEL DP35DP and not a Gygabyte one.
I will have a look on this tool to see if there are cpu spikes ...
kwild
Post by kwild »
Oh,i think it was a Gigabyte DP!
Anyway the DPC problem is not a Gigabyte problem only...
Try the tool and try to disable any network adapter as i've already say.
dbmac
Post by dbmac »
What is the mouse manufacturer?
Is there any mouse software loaded at bootup (run msconfig to see)?
Same thing with your video card - is there any Matrox apps running?
/dave
Neutron
Post by Neutron »
there was a problem like this in 3ds max caused by microsoft intellimouse drivers. if you have that unninstall. you dont need it anyways.
or
it might not be the mouse, maybe its the video card.
what if you drag windows around, does it get worse?
gustav
Post by gustav »
dbmac wrote:What is the mouse manufacturer?
/dave
Hello!
Its a logitech mouse - In my installing process I allways diable all startup apps in msconfig : so no mouse software loaded.
For the video card : matrox parhelia 128 pci-express, I don't install all the software - I only install the last video driver
yes, I will also try to disable the network adapter
dbmac
Post by dbmac »
What window are you working in when the mouse interference happens - SX3 or Scope?
Also, what asio driver is loaded in Scope, and what ULLI latency are you using?
Running out of ideas here.
/dave
gustav
Post by gustav »
kwild wrote:Anyway the DPC problem is not a Gigabyte problem only...
DPC : no spikes at all - even no little spike when moving tyhe mouse and dropout happens
network disabled :
moving the mouse & dropouts :
I just tested configuration with only 1 monitor (second screen not attached in display management) :
moving mouse on the sx-windows produces dropouts, I tried to run around with the mouse without going on the sx-windows and there are far less dropouts. but its not easy to say. The easiest way to produce dropouts to move the zoom in sx.
microsoft intellimouse drivers : did not find anything like this
drag windows around : I'm not sure if I understand this right, I tried to follow the border of the sx-windows with mouse changing constantly appearance - no dropout
Perhaps its not the mouse but the videocard ?
_______________________________________
our music at http://algufr.bandcamp.com
and at http://alg95.bandcamp.com
more music at http://hurpasard.free.fr/index_en.html
gustav
Post by gustav »
I just read some trouble shooting information in the matrox manual - and I saw : Try start in vga mode
seen and done : there is no way to produce dropouts !!!
gustav
Post by gustav »
It comes better - I allways used the last driver (the SE United driver of december 2008)
no good ! :
I installed the HF driver from May 2007 and no dropouts no more !
I have to make more test this configuration ...
Neutron
Post by Neutron »
Im glad you looked in to the video card. problems with the mouse cursor are often in the video card/drivers
I hope its fixed and you can get back to serious business :D
I remember back in the day those matrox were the thing to have for scope. is there any reason to use it over a modest ATI or Nvidia passive card?
gustav
Post by gustav »
thanks to all of you !
