Midi Problem with Cubase 3 & Luna 2
sputniknik
Post by sputniknik »
Hello Planet Z users,
I don't understand where my mistake is...
I connected Luna MIDI A Source with Sequencer Midi Dest 1 but don't get a signal in Cubase.
I checked the cable, the keyboard and my midi track in cubase is "creamware MIDI in/out".
The Cremware Midi In/Out device is activated in Cubase.
What did I forget ???
THANK YOU THANK YOU THANK YOU FOR YOUR HELP
Greetings from Munich, Germany
Re: Midi Problem with Cubase 3 & Luna 2
it looks good.
did you plug into the "midi in" on the luna? they aren't marked. have you tried the other plug?
have you used a midi monitor(in the midi menu at the top of the routing window) to check for signal in Scope(luna midi source to midi monitor)?
are you seeing midi activity in the monitor on the Cubase transport?
obviously, you're setting up the routing window BEFORE opening Cubase, correct?
if there's midi going into the card, it MUST work.
sputniknik
first of all thank you for your quick answer :)
i tried both "midi in" plugs on the luna.
i used the midi monitor and it shows nothing :(
no midi activity in cubase (not in transport and not on the midi track itself)
when I try it with the virtual midi keyboard (the one from the sfp software) i get midi signal in cubase ???
and yes, i change the settings before i open cubase...
in that case, the problem is the midi cable, the adaptor going into the luna card, or the controller. are you SURE you're using the controler's midi out(sometimes crazy things happen...)?
djstudio
Post by djstudio »
Hi, try to remove routing from Luna midi in A to In sequencer destination and save as default.
I have solved!
fidox
Post by fidox »
hi,
this is my default scope project for midi using with cubase, i use it always for my starts when creating tracks,
