My motherboard is annoying... it radiates electric noise onto on of my pulsar cards.. It's not a problem with my cards, i have tested with others and its the same problem.
I also need to disable a core to get things running smoothly in xtc mode.
And when i connect a controller (bcf2000) and use it in cubase/reaper, i get midiloops..
there is just a general grounding problem with the motherboard. It detects usb things connected out of the blue..
So i'm getting another one..
I think i have read that intel boards work fine??
This i my current setup:
ASUS M2N-MX SE PLUS
http://www.asus.com/products.aspx?l1=3& ... odelmenu=2
cpu:
AMD athlon 64x2 dual core processor.
I want to keep the CPU.
thanks alot!
						What is a good know configuration with xtc mode?
- the19thbear
Re: What is a good know configuration with xtc mode?
I'm using a DFI LanParty x38 DK, with a quad core, and XTC works perfectly with Reaper.
I think DFI makes the same series for athlon processors.
- the19thbear
thanks!
I'm having trouble finding a place to buy it in denmark... but keep up the good ideas!
- the19thbear
thanks!
the problem is that intel motherboards dont support amd cpu's
any other suggestions??
- the19thbear
please suggest newer boards only.. i want to be able to buy it still
thanks!
 thanks!
- the19thbear
found this one.. but for that price i can get a new intel motherboard with cpu...
http://www.dfi.com/portal/CM/cmproduct/ ... &mode=view
it's a little expensive..
then i found this, alot cheaper!
http://www.asus.com/products.aspx?l1=3& ... odelmenu=1
any comments on this one??
- the19thbear
well.. bought a new motherboard, and everything works PERFECTLY in xtc mode now!!
