hey!
i ahve been using the sts 4000 sampler a lot these days...mainly for drum kits...but there is one question I have...why is it that i am unable to drag some of the .wav files i have into the sampler?...i know files i have are good..they look and sound fine when played through other software..what am i missing?
wav files in sts4000
Guest
Guest
Subject: Oh boy, you can do that
you can drop wav file on the sts (at least in the PC version / Pulsar OS version 2.01).
walkthru:
1: create a new program from the sts main panel
2: create a new key group
3: clic on keygroup "zones" menu
4: drag your .wav from the file browser of the pulsar enviroment to one of the four blank keygroup zones.
5: adjust root key, ind. out, tune, whatever for every wave you dragged.
easy eh???
note that you can still save the created sts program (.p file) and maintain the samples to wav. right click on the program Save or Save As... the program will be saved as .p file, the samples remain standard .WAV file (handy if u want to moify them with an external editor).
walkthru:
easy eh???
Guest
Subject: I've never been able to do so
I've never been able to load a Wav file into the STS. I think you don't have any other choice, but to convert your Wav files into AKAI S1000 files. This is done with a program called "S1000 Program maker for Creamware Pulsar", you'll get it here:
http://www.abel.co.uk/~maxim/akai/
You have another program called Awave, which also converts your Wav into AKAI samples. Hope this answers your question. I've try to load Wav samples in many ways, but it was useless. So we need to convert.
Nestor
Nestor
Guest
Subject: extra header information causes WAV to not load
SoundForge defaults to "Save Header Information in .WAV" when you save your WAV files.
The STSx000 doesn't understand this non-standard header information, and refuses to load them.
Solution: When you save your .WAV using any audio program, be sure to set "Save Header Information" to "None" or "Nothing." Also, as mentioned, your .WAV files must end in ".wav" for them to even be seen by Pulsar.
Guest
Guest
Subject: Silly boy
Thank you very much Playback… And don't be sorry, I'm the one who's sorry for been so slow, because I actually read the manual several times, but didn't understand. Of course, it is a language matter, but… boy… herrmmm…
I'm glad it works, thanks very much for the explanation, I'm going to try it right away.
Nestor
Nestor
