How about this setup?
polyglycerin
Post by polyglycerin »
Mainboard: Intel® DP35DPM / P35 Express, 1.333 MHz, 1x PCIe x16, Sockel 775
CPU: Intel® Core 2 Quad Q8200 / 4x 2333 MHz, 2x 2048 kByte, 1333 MHz (Quadpumped), Yorkfield
RAM: Corsair DIMM 4 GB DDR2-800 Kit / 4096 MB, CL5 5-5-18, 2, PC2 6400
PSU: Seasonic S12II-430HB / 430 Watt, ATX12V 2.2, ATX 2.03, EPS, 4 Stecker, 6 Stecker
Video: Asus EN8600GT SILENT/HTDP/256M
Case: Cooler Master Centurion 534
DVD-Burner: Samsung SH-S223F
HD (SATA): Seagate ST3500320AS 500 GB
Re: How about this setup?
sure.
be sure that you have the 1.8volt memory modules. also, it would be a good idea to have another harddrive to use as "tape". all project data(tracks, midi and project files) should go to the second disk and the first "c:" drive should be only programs and os.
polyglycerin
thank you!
if you need help with the setup, just ask....
LeXo <3 pulsar
Post by LeXo <3 pulsar »
Q6600 is better than q8200 and is more cheap ;)
2 or more HD is the best choice for a DAW i suggest a 150 GB Raptor and other 500 GB for ur project files :D
