how to incert p100 into stm1632
sandrob
Post by sandrob »
i don't know how to insert p100 reverb into stm1632 mixer's inserts, because i can't see all plugins on list in stm1632 inserts.
so, i can see and use all plugins include p100 in projects (i have p100 on main list) but i can't choose them in stm1632, because p100 miss in stm1632 inserts list.
Re: how to incert p100 into stm1632
Try a drag and drop from the list above and see if that works.
When you succeed in that endeavor you'll know it's working, then you put A100 in the proper folder, as I believe that is the trouble. First try and find it the the Devices drop down menum then Effects, etc.
Don't worry, I never read the manual either. :roll:
sandrob
Post by sandrob »
yes! :)
drag&drop from menu above working!
thanks :D
sandrob
Post by sandrob »
stardust wrote:the insert list is the list of devices in the devices / effects mono and stereo depending on the insert slot.
Put a copy of your device there andyou see it in the list.
i already have p100 in the devices/effects/reverb and i see p100 in the main manu above.
also, i have all plugins in the stm1632 insert menu but p100.
so. XITE-1/4LIVE solved my problem, but anyway is interesting to me why i can't insert p100 in the stm1632 on "normal" way.
spacef
Post by spacef »
Devices/Effects/ STEREO/....
(or for mono) Devices/Effects/ Mono/....
available in context menus after Restart of Scope.
Exactly right these guys are.
Sorry I didn't come back to finish and check up.
Mine was a temporary solution just so you could see it worked.
I have several synths and mixers, not all of them retrieve from the same folders, so comparing the paths and duplicating some are necessary.
