Macos9.2.1>DP>SCOPE>sudden clicks and pops - unusual
edmann
Post by edmann »
Greetings EXPERTS -
After years of running this rig successfully, suddenly out of nowhere I am getting clicks and pops in the audio when recording. Whether streaming in thru ADAT, or - most dreaded - when processing audio tracks (or track) thru SCOPE effects and recording back into Digital Performer - clicks and pops. Since I have worked successfully in these ways for years, I am stumped - stymied - cannot find solution, so far.
Thanks in adavance for your input! I appreciate it very much.
Ed Mann
Mr Arkadin
Re: Macos9.2.1>DP>SCOPE>sudden clicks and pops - unusual
Post by Mr Arkadin »
Have you tried the obvious things like re-seating the boards, perhaps carefully cleaning the connectors? Checked the STDM cable if you have one? Jiggled all the ADAT connectors?
Back in the day i used OS9.2.2 - don't know if that made a difference (it was a while back).
Have you installed any new software lately?
edmann
Post by edmann »
ah- I did not reseat the card, that feels good. thanks film at 11
not new software for this computer
alfonso
Post by alfonso »
edmann wrote:ah- I did not reseat the card, that feels good. thanks film at 11
Ciao Ed :)
I'm not a Mac expert but in the pc world the few reasons I have encountered for clicks and pops are from:
1) hard disc almost full and/or fragmented
2) USB sharing IRQ's with Scope card, but I don't know if this can be a Mac problem or not.
3) Video Card taxing the system too much.
Anyway, if nothing changed, the hard disk could be the culprit....
edmann
Post by edmann »
thanks Alfonso I will check out these various things - I did reseat the card but it made no difference.
what kind of Mac is it ?
a Dual Double-Mirror-Door ? Quicksilver, Sawtooth ?
edmann
Post by edmann »
G4 450 - forget it's pet name, a generation after sawtooth - with an OWC 1200 mhz processor upgrade and 1.25 GB RAM running OS 9.2.1
I rolled back from OS 9.2.2 because I read (here, I think) that Scope may like 9.2.1 better and I used to have some problems in 9.2.2
thanks again
well, assuming you (probably) used the classic Mac method of keeping a copy of the previous environment, I wouldn't expect install forward/backword problems.
If the system has been physically installed, then I wouldn't hold my breath on the reliability of the process (under any late #9 system), though.
Anyway 1.2 G Ram is pretty much for the box and most likely made up from different sets.
A Ram slot may have contact problems, or a faulty chip might be possible sources.
Remove and re-insert, and if it doesn't change a thing, try with only some of the memory Dimms.
edmann
Post by edmann »
thanks Tom
odd thing is that I have had no previous problems like this, with the same setup
but the recording disk is pretty full, it's level of fragmentation considerable - all being remedied now.
film at 11...
thanks again
Ed
