Hi Guys,
The S&H Output Lag in Prodyssey running on the Noah doesn't seem to function correctly when set from the Noah device itself (via control or editing the patch) or via midi!
Basically a setting of 127 is Max and <=126 is min. It is acting like a switch.
If you edit it from the Noah app on the PC it works correctly.
Has anyone else seen this?
Cheers
Andy
						Prodyssey-S&H Output Lag
Re: Prodyssey-S&H Output Lag
Not yet, i'll have to check it out !!!
I also found this post http://www.planetz.com/forums/viewtopic ... 33&t=13583
Seems that it doesn't work!
This is a real shame
Andy
Andy
EXT Source also doesn't work correctly from the Noah but does over midi (receiving only, send is knackered)!
Also Pitch Bend has to be set using different cc values that the ones sent out!
I wonder are these problems specific to the Noah version or are they the same on the other platforms?
Andy
Andy
