Installing scope 4 problem
noise_maker
Post by noise_maker »
hey guys
I'm finally installing Scope 4
and Ralf sent me the new registry codes (which are much longer than I had before)
so here is the problem:
the old keys still show up in the new setup, I can't overwrite them.
I'm not sure, but I think that because of the mixup of the old keys and the new keys don't let me to press next to continue the installation.
anyone know this problem?
Shroomz~>
Re: Installing scope 4 problem
Post by Shroomz~> »
Try to import the allkeys file again.
it doesn't matter if there are keys from absent cards in the file, but the import may fail due to (say) 2 dots in the filename - I've had that recently :o :D
trash the scope folder and start over.
noise_maker
I deleted the whole sfp folder and tried to install but it still doesn't let me press next.
maybe wrong keys ? or what ? ralf sent it to me, I copy past the keys.
does this key seem ok to you ?
"0XHE***CFWB65D01DLS8**LLW8X1DOB8S****8S1DLSANIE" (this one is for the SCOPE 4.0 Software, I replaced some of the letters with *)
noise_maker
Shroomz~> wrote:Try to import the allkeys file again.
I don't have 'allkeys file'.
how can I create/get one ?
noise_maker
yo!
nvm guys
I've figured out that the serial is only the first 12 letters/numbers.
Thank you for the support!
sure, but the keyfile can be imported, you don't have to type manually. no matter though, i'm glad you've got it going.
