What exactly is that ASIO patch supposed to fix? Is it only for Cubase users and if so, why? What was the deal with that?
Sorry - I read some of the earlier posts on the subject - still not sure what it's supposed to solve but it apparently has nothing to do with anything but Cubase, right?
Sonic Core ASIO patch
- krizrox
- Ralf
Re: Sonic Core ASIO patch
Hello,
asioscope_cubase_4.1_patch.zip
Release: 3. Juli 2008
*ENGLISH*
Patch for ASIO SCOPE with Cubase 4.1,
Operating System: WINDOWS XP only!
This patch solves the problem of using SCOPE with
Cubase 4.1 at other sample rates than 44.1 kHz.
Please do the following:
- Exit the SCOPE and CUBASE programs
- Copy the file asioScop.dll to the directory
/App/Bin/ inside you SCOPE installation,
i.e. "C:/SCOPE4/App/Bin/"
(Replace the existing file asioScop.dll when copying)
- Reboot your computer
*DEUTSCH*
Patch für ASIO SCOPE unter Cubase 4.1,
Betriebssystem: WINDOWS XP only!
Dieses Patch löst das Problem, dass SCOPE zusammen
mit Cubase 4.1 nur mit einer Samplerate von 44.1 kHz
betrieben werden kann.
Bitte gehen Sie wie folgt vor:
- Beenden Sie die Programme SCOPE und CUBASE
- Kopieren Sie die Datei asioScop.dll in das
Verzeichnis /App/Bin/ Ihrer SCOPE-Installation,
also z.B. "C:/SCOPE4/App/Bin/"
(Die in diesem Verzeichnis vorhandene Datei
asioScop.dll muss dabei überschrieben werden)
- Starten Sie den Rechner neu.
cheers
ralf
*ENGLISH*
*DEUTSCH*
cheers
ralf
Your presence here charges the members up energetically whenever you post,
By all means stop in and say Hello whenever you wish.
With Kind Regards,
DiaperJim.
With Kind Regards,
DiaperJim.
