New B02 "PoleCat" please delete any polyfilters you downloaded.
Its a polyphonic filter bank. the frequencies of the filters are controlled by which MIDI notes are being played. that way it is very easy to control from a sequencer or keyboard. it is very fun to play with. all thanks to a tiny atom file i never knew about before
First section
monophonic
comb filter removed replaced with inserts
update: there are 2 imputs with individual mono inserts, not left and right, but 1 and 2 they can be completely different sources, or the same thing with a different insert on either input. then you can control the mix of the inputs sent to each filter by either a simple mix knob or modulated.
The input signal stream is then divided in to the polyphonic section, so each instance will be affected separately.
polyphonic section (bottom part of the interface, always visible)
the 3 bandpass filters can all be played from the keyboard polyphonically. and the octave and fine tune can be changed.
If you have 3 voice polyphony thats a 9 channel filter bank.
each of the 3 filters can be modulated also by LFOs, envelope generators and follower The pan of each one can also be modulated by any of the same modulators. or the input source can be modulated. (mix between input 1 and input 2) there is a switch between potentiometer pan and modulated mix, or potentiometer mix, and modulated pan.
update: the follower can follow either of the inputs or any of the filters outputs (pre fader) so you can actually use one of the filters as a "detector" to control the follower, and that filter could be modulated by something else.
monophonic output
There is a modulatable (monophonic) stereo Formant filter on the output as well.
it sound very cool to play a "chord" of filters over an input that is rich in harmonics.and make noise, sound effects or drones follow your harmonies or chord progression.
if you have a sequence that covers several octaves, and have the filters set to those ocataves you can bring in and out different melodies of harmonics on the different bands.
For an input sound that is pitched, its really cool to hear new melodies that always work, because they are harmonics of the input.
1 more possible change. I am thinking of a sort of tempo delay section feeding back from the output to the input
and yes i know its a bit of a DSP
Of course THANKS FOR THE KNOBS SHROOMZ!
