is it possible? i would like to send an audio signal to something which is polyphonic, process it, then poly mix it back to monophonic in the usual way.
if it is just connected directly it only plays every Nth note (n is polyphony)
so what i need to do is split the stream up so all the instances of the poly part can see it at the same time.
Any SDKers know if there is something that does this?
edit:
OOPS never mind i found it
tiny little innocent looking thing it is !
