EDIROL UM-2EX
djstudio
EDIROL UM-2EX
Post by djstudio »
Hi to all,
because i want to buy this interface i need to know if anyone have it.
My question: is it work well with USB 1.1 or is it only for USB 2.0?
Thank you
Shroomz~>
Re: EDIROL UM-2EX
Post by Shroomz~> »
It'll work with USB Spec Revision 1.0 or higher, so you shouldn't have any problems.
In the case of USB I think manufacturers have to meet the specifications laid down by some kind of USB standards authority (not sure what it's called), so for the meantime all products with USB still have to support rev 1.0 upwards.
Mark
djstudio
Re: EDIROL UM-2EX
Post by djstudio »
Thank you for your reply.
I have some confusion about difference between UM1 and UM2.
The UM1 have trhu switch but UM2 have not
Which the best between both?
Re: EDIROL UM-2EX
tomayto tomahto....
it depends on whether or not you require the through port.
Shroomz~>
Re: EDIROL UM-2EX
Post by Shroomz~> »
If you're sure you want to go with Edirol, the UM-1EX seems like more of a portable solution for laptop users on the move, so unless that's what you need it for I'd go with the UM-2EX. The UM-3EX is what I'd buy if you can afford the xtra 30 euro because they can be daisy-chained to give you a 9in/9out midi interface. That just means that if you wanted to expand, you wouldn't need to worry about changing your interface or using another separate USB connection.
djstudio
Re: EDIROL UM-2EX
Post by djstudio »
I have not problem for extra midi because i have the Roland A-880 midi patcher.
The question is if the UM1 have more function or if the UM2 is the follow of UM1.
So I prefer to buy UM1 with only 1 midi in and 1 midi out if it have more function.
If UM2 is the follow of UM1 I prefer to buy this interface so I can have 2 midi out
The price is the same!!! This is strange
