I have serios problem with syncronize audio and midi with my pulsar 2 and cubase....please friends help me, anyone have a good configuration for my system?
Another question...pulsar 2 working in windows 2000?
Thanks ^_^ Eber
pulsar 2 syncro with CUBASE (by Eber Dimarti)
Guest
Subject: delay
hi,
i had the same problem at the beginning of using pulsar 'cause i used wav source/dest which uses direct sound drivers , use asio source/dest instead.
you should configure your cubase to asio also:
in audio/system/asio device set to asio scope , that should solve your problem , good luck.
hi,
