audio input output switch ?
widy
Post by widy »
i search for a solution for the following setup:
To connect 2 line out ( one from scope one from another soundcard )
to 3 differnet destinatrions
- 1) active box
- 2) hifi system
- 3) converter box for audio to transmit audio over wlan to a nother room
whats the best/cheapest way to switch the 2 line out to the 3 different destinations
i searched for some switch .... but i found only switches with 3 inputs and 1 output or 1 input to 3 outputs ... but i prefere one box to switch input and output ...i also searched for some cheap mixer .. but most of the mixer has only 2 outputs .. sterio mix and control room ... ( but i need 3 outputs )
any suggestions please ?
lg widy
lg widy
Re: audio input output switch ?
yeah, there were old hifi boxes like this made by Dbx and others for tape recording/monitoring. i have an old Rogers Sound Labs box like this. you'll have to scour old home hifi electronics to find such a thing. a box like that would be very easy to make. the box i have has several three way slider switches. top is buss a, bottom is buss b, middle is off.
i believe that what you are looking for is called a matrix switcher.
widy
Post by widy »
i bought samson C-control - Control Room Matrix
http://www.samsontech.com/products/prod ... rodID=1650
and it works fine for my needs :)
lg widy
lg widy
great!
