Hi!
I have the following issue:
I've installed Cubase 4.1 newly and then SCOPE 4.5. Since I have Cubase for 10 years now I've been through all the versions.
My last Vst-Plugin Folder was located in the Cubase SX 2 folder.
Now I've installed only Cubase 4.1.
After loading a project in Cubase 4.1 the inserts are missing (MULTI FX S, vodoizer, etc.... - Vocodizer loaded directly in an insert without the MULTI FX-device).
The VSTi Instruments are still loaded (EDS16i, ....)
I've tried to create a second VST-Plugin-Folder to recreate the "old path" c:/....../Cubase SX 2/VSTplugins
and copied the XTC-folder there.
No success.
I've also created my former folder structure of c:/SCOPE with the several Devices folders and XTC-Devices.
The seq-path in the cset.ini file is also set to the new folder. I've tried to add a second path to the new folder.
Didn't work.
So how can I open a cubase-project with the XTC-Inserts?
Where do the inserts refer to (c:/scope/devices or ??) ....
Any ideas??
Thank you
Harry
XTC Inserts not found after new installation of Cubase
- rhythmaster
- rhythmaster
Re: XTC Inserts not found after new installation of Cubase
OK. Thanks for the hint. I'll have a look
H.
H.
Another possible cause could be your scope path if you changed it! Better to reinstall with old path directly.
(and by the way take care to your presets path too!).
let us know how it goes!
cheers
cheers
- rhythmaster
Hi!
Finally I managed to get it working again except for Vocodizer - although I posted years ago that Vocodizer runs as XTC-Insert
The renaming of several dll's didn't work ...
Finally it wasn't the path of the Cubase/VSTFolder but I can't also post a final solution.
I checked the contents of the Cubase/VSTFolder the Scope/Devices and Scope/DevicesXTC folders became desperate and
after some twiddling it worked for the MULTI FX S (with the included plugins).
It's also a thing of restarting, installing, restarting, hoping and so on ...
So I hope for SCOPE 5 to have a smooth XTC-integration ...
Sorry for the lack of details
Harry
Harry
