The Most Incredible DRUM COMPUTER !!!
kensuguro
Re: The Most Incredible DRUM COMPUTER !!!
Post by kensuguro »
hehe... why a bass drum of all things?
ladiki
Post by ladiki »
What do you think about this Jimmy...
Internal Specs
Asus K8N-SLI Premium Motherboard
Dual Core AMD Athlon X2 4800+ Processor
Dual Channel 2GB DDR 500 PC4000 memory with Thermaltake Blue Heatsinks
Dual XFX Nvidia 7800GT Video Cards in SLI Mode
Dual Danger Den NV-78 Video Water Blocks
Dual Plextor CD/DVD RW Slot-Load Drives
Dual Gigabit Ethernet Onboard
Triple Western Digital Raptor 10,000 RPM 74GB Hard Drives (2 in Raid Stripe Set, 1 for backup)
Sound Blaster X-Fi Audio PCI >>>>>>>>>>>>>>>>>>>>>>> they miss the real nitro system turbo Charged.... XITE..... :)
Enermax 620W Power Supply (Single 120mm Fan)
Floppy and USB Multimedia Card Reader
Danger Den D5 High Flow Water Pump with Polarflo TT Series Chrome Housing
Black Ice Pro Chrome Radiator and 120mm Fan
Polarflo TT Series Chrome CPU Waterblock and Waterpump Housing
108Mbps Wireless in PCMCIA (PCI)
1/2" ID (Inner Diameter) Silicon Tubing with Spectre Magna Hose Clamps
Frame Specs
The frame is consistent with classical chopper motorcycle frames. 1" steel tubing is used for the majority of parts. Although, the backbone is 1.5" steel tube and the neck is 1.75". The frame is tig welded, welds grinded and sanded prior to powder coat or paint.
The gas tank, oil pan/power supply tray, spoiler, seat pan, and face plate are 3/32" steel.
The motherboard tray and component trays are 3/32" aluminim.
Wheels have been mounted into the rear swingarm pivot for mobility.
The seat pan is mounted to a hinge for easy access to the power supply.
The oil pan and air scoop are detachable allowing for easy access to computer components.
Motherboard tray slides out rear of chopper for easy maintenance and assembly.
Regards,
Sam
Jesus, Joeseph, Mary.........and I ain't even religious !!!
That's incredible. I cannot let my son see this, it is worse than Pornography as he will want one, and I will be broke !!
I absolutely love that since I am quite fond of custom bikes. That is the best gamer specs too. I am shocked there is no SSD for extra FPS.
What speed is the FSB? With all of that water cooling it's gotta be high. Onboard memory controller of the AMD's allows super low latency RAM settings too I'll bet. CL3 Maybe?
Most Excellent...............Thank You Brotha' Man Ladiki.
