<a name="planetz-file"></a><a href="http://www.chillproductions.com/dx/neut ... .dev"><img src="/forums/images/file_icon.gif" border="0" alt=" File"> File</a><BR> <a name="planetz-tag"></a>Price ($USD): 0<BR> <a name="planetz-tag"></a>Type: Synth<BR> _____________________________________<BR><BR> I was screwing around with an experimental oscillator, it is sort of a "convolver" anyways I have made a version of the transplanet with this oscillator instead, Everything else about the synth is the same as the Transplanet (morphing etc)
I expect i will make some other variations of the Transplanet as well (especially one with traditional oscs and the filter from PXR5)<BR><BR><a name="planetz-fileimage"></a><IMG SRC="http://www.neutron7.com/images/transx.jpg" BORDER="0">
-=NEUTRON=- Trans-X
- Neutron
Zooit
Hy,
ain't Im right, that this Synth should "morph" between the settings?
So, when i just use "nacked" osc. where the lower is esp. transposed up one oct. and I morph betwenn the lower and upper settings, should I hear a glissando??
I just hear a mix of lower and higher osc.
It seems just to be mixing nt morphing between the settings...
- Neutron
JoeKa
I really like this one, you can get very good atmo sounds out of it, cool or warm sounding, and very "living".
But unfortunately it alway forgets its MIDI channel. No matter if I save the preset or just the project or both, whenever I re-open the project, I first have to set this devices MIDI channel... very small but really annoying bug, as I sometimes let a project lie aside for months until I continue my work on it, then I have to look up all other devices´ channels to find out, which this one might have used.
Will it ever be fixed?
- Neutron
