STM2448
wsandoya
STM2448
Post by wsandoya »
Hello people,
I am new using SCOPE so I have some questions...
How can I send "In1" signal to 3 or 4 distinct BUS, I need do it because I'm trying separate my DRUM in 3 distinct FQ, after I will group this in one new Input Channel. I am working in MONO.
Re: STM2448
the manual has detailed descriptions of that mixer but basically, there are 8 assignable subgroups. disable the green light that indicates that the channel is going to the mix and then assign to the bus. if you need to, you can return the bus to a channel or aux input and then send it to the mix.....basically, the same routing that can be done with a hardware mixer can be done in scope.
wsandoya
Re: STM2448
Post by wsandoya »
Thank you bro!!! your solving my problem!!!
Thanks!!!!
alfonso
Re: STM2448
Post by alfonso »
Also remember that you can send a single ASIO output to several mixer channels...any output in Scope can go to any number of inputs.
wsandoya
Re: STM2448
Post by wsandoya »
ok, i'll remember!!!
Thanks!!!
