"No DSP Placement" error
Kenf
Post by Kenf »
I have been sucessfully using my Pulsar2 and Electra cards for many years using the same projest in XTC mode. I had to re-install windows due to a windows config file error. I have re-installed SPF 4.5 and my XTC.pro no longer works. I get a capacity limit error "No DSP Placement" The project works fine in 'normal mode'. I have been through and connected each I/O module in turn. The project fails as soon as I connect anything to Z link dest. I have spent hours and hours trying to solve this problem and am feeling very disheartened...
I have a ASUSP4P800 mobo. The Pulsar is in slot 1 and Electra in slot 5 both share IRQ 21. I am using Cubase 3.1.
Any ideas? Regards
Kenf
Kenf
Re: "No DSP Placement" error
Post by Kenf »
I have tried the both cards on there own and they both work individually in XTC mode.. but not together when I use the Z link. I re-installed windows with the cards in place do you think it may be worth taking the cards out and re-installing windows. Then the cards one at a time???
Regards
Kenf
try running the Scope installer again(over the top of the old install).
perhaps this will fix whatever file has become corrupted....assuming that file corruption is the problem...
Kenf
Post by Kenf »
Thanks garyb... I have tried that but will have another go.....
Regards
Kenf
MD69
Post by MD69 »
Rebuild your XTCproject.pro, some internals might have changed after your re install.
Cheers
yes, good call.
Kenf
Post by Kenf »
Thanks for your help... I have just realised I have been modifing XTC.pro not XTCproject.pro.... What an idiot I am... All works just dandy now... just like it used too.
Regards
Kenf
Kenf
Post by Kenf »
:) :) :lol:
Thanks again
