A tape echo device!! with variable speed and feedback *WITHOUT* zipping!
It must be possible!
( there are fine tape echo simulations, but not with variable speed without zipping..)
Tape echo!
- the19thbear
Re: Tape echo!
This is probably problem with scope, but not problem with other hardware. My Yamaha A4000 sampler use 5s CtrlDelay and StereoCtrldelay with smooth modulation time/tempo and feedback modulation, this fx is totaly great.
- the19thbear
Re: Tape echo!
yep its a problem with scope... but it shouldnt be!
i am sure there is a way out of this!
Re: Tape echo!
There was supposedly at some point a smooth modulateable delay from one of the early DP devs, i cant remember who, maybe it was orbitone.
Re: Tape echo!
I've asked for this some time ago with the same answer: some atoms, needed to build such a device, are missing in the SDK.
If my memory doesn't fail, a developer (I didn't remember who ATM) tells about a device he was working on, that workarounds the issue, but consuming HUGE amount of DSP (someting like a whole scope pro) ...
Re: Tape echo!
What about Celmo Tape Echo Sim?
