Multiband Compressor XTC
Do you know any brilliant Multiband Compressor working with not linear phase behaviour????
						Re: Multiband Compressor XTC
Taken when Optimaster was published .... there is a good chance it is IIR based
cheers
						cheers
Ok Thanks
How can i check out if it is the second release? cause i have optimaster would be excellent keep using it
						- the19thbear
There is a free multiband comp wich is GREAT! dotn know if its linear or what... and forgot the name of it:) But ill post it as soon as  know!... in the meanwhile do a search in the device sections! i think shroomz did the gui?? i might be wrong though!
						- the19thbear
Basically I would compare the phase between the unprocessed signal and that same signal going thru optimaster with a frequency sweep generator.
Does MuBaCo works in XTC???
						- the19thbear
