Error message
ZaSS
Error message
Post by ZaSS »
Hi !!!!!
You know this?
Can´t find DSP Add 2N
Regards!!!!
Re: Error message
What's loadad in the Project window?
Perhaps a pic would yeild a quicker fix. I have had many similar missing dsp. messages over the years, and don't recognise this one.
Lima
Re: Error message
Post by Lima »
Seems like a missing DSP file. If it's needed for a standard Soniccore's device maybe you should reinstall the Scope software. Otherwise (if it's required by a third party's device) you should watch in the forum if the file has been released later.
Another problem could be a wrong attribute of some files. Refear http://www.planetz.com/forums/viewtopic ... 13&t=18596 for futher informations.
hope it helps! :-)
Re: Error message
be sure the file is not marked "read only". if it is, uncheck that attribute(in properties).
you can also delete the file(from scope/app/dsp) and then manually recopy it fromn the install files.
kylie
Rank-o-phile
Re: Error message
Post by kylie »
stardust wrote:Good point Lima. Valis' batch file is temporarily not available from that thread. I assume it is due to the forum SW upgrade. stay tunes Zass
it is still there. just copy the link in the first line into a new browser tab/window and tadaaa there is is.
(or just click here :) )
-greetings, markus-
ZaSS
Re: Error message
Post by ZaSS »
Hi again !!!!
There was another installation error .I am trying to install it but I don´t understand why cannot.
I was buy it two weeks ago to work only under Cubase SX2 ,at moment .
I read a lot of manuals ,forums and post replys without luck .
I can´t solve ASIO TEST .
Only run Cbsx2 a few seconds :
44.1 16bit
1 Halion line +1 BlueSynth line and crash .
PC:
Asus M2V+MX
AMD x64 3800+
3 gb DDR 667
Whta´s the matter ?
ZaSS
Re: Error message
Post by ZaSS »
Captures:
XTC PROJECT.jpg (47.47 KiB) Viewed 4868 times
ASIO Mulmedia.jpg (22.02 KiB) Viewed 4868 times
ASIO Full Duplex.jpg (11.5 KiB) Viewed 4867 times
ZaSS
Re: Error message
Post by ZaSS »
Mastererv tes under amd x64 3800+ dual core 3 gb ram xp sp3 :
Pci Error Image.jpg (150.17 KiB) Viewed 4735 times
ZaSS
Re: Error message
Post by ZaSS »
Hi !!!!!
My new system:
AMD x64 3800+ xp sp3
Mobo ASUS M2V MX
Pulsar 2
I was try on another cpu:
AMD 2600+ XP SP2 and seems to run ok on XTC mode but with the same masterverb test result,4 masterverb
How can resolve it ?
ZaSS
Re: Error message
Post by ZaSS »
Hi mate !!!!!
wich mobo I can buy for my amd 3800+?
Please let me know
