Hi !!!!!
I´m looking for a simple XTCproject for PULSAR II to use with CbSx2 ,I only need to connect my synth to work only under it.
I edit the latency too and only run a few seconds
I try and try without fortune ,never get the asio test ok.
Please ,I was buy it two weecks ago and only receive errors ,and I´m going crazy.
Regards from Barcelona !!!!!
						XTCproject.pro >>>>>>> HELP <<<<<<<<
Re: XTCproject.pro >>>>>>> HELP <<<<<<<<
Many thanks r reply but I read it and doen´t run
regards !!!!
						regards !!!!
A scope project take into account the hardware on which it run and how it is installed. So you cannot directly reuse a scope project.
Anyway, did you check your system in SFP mode first? Does it work OK?
Check your setup with the masterverb test in order to know how many ASIO channels you can use.
By the way, Cubase store informations relative to your XTC VSTi in a file. Particularly, the VSTi latency which is relative to your hardware latency setting. If you have changed your latency in between, you ought to update these informations in order to your vsti to work correctly (crackling noises, ...).
If you proceed step by step you should have it working ... except if there is a hardware problem (motherboard compatibility, ...)
cheers
cheers
"Check your setup with the masterverb test in order to know how many ASIO channels you can use"
How can I do that?
Regards !!!!
						How can I do that?
Regards !!!!
check there:
http://www.planetz.com/forums/viewtopic ... 19&t=17078
Basically, install as many masterverb as you can until you get an eoor message
Only can run 4 reverb with 6 dsps?
There is a good chance your install is not correct!
Check out irq sharing, and PCI latency
Could you tell us more about your hardware (main board, chipset, ...)?
cheers
cheers
didnt understand what is happening certainly with your card but i have/had a probl like that...XTCproject still is not working anymore and audio too in my Scope Srb.
The only thing i did to save the card and use it is putting a jumper in 2-3 pin . Doing like that any xtcproject or sfp are disabled if not loaded therefore you can use only the VST plug ins...As well you will need to get another soundcard beacause any asio driver is loaded.
Otherwise i strictly advice you to visit this link http://www.planetz.com/forums/viewtopic ... 32&t=21703
it has been very helpful for me, hope will be so for you too..
- the19thbear
and did you do this test in xtc mode? try doing it in normal sfp mode first..
Many thanks 4 replys !!!
It seems to be ok only under one processor.This is the only way for this mobo.
Regards !!!!!
Regards !!!!!
