here's my problem:
If i select more than one voice with modular, when I play one note, the select voice number will always play, so if I select 3 voices and I trigger only one note 3 will still play and it sounds terrible, it's just random notes playing with the one I play, has this been a problem for anybody else or am I doing something wrong?
thanks
						more than one voice?
Re: more than one voice?
It could also be that the modular receives in omni mode (all channels) and you have  a master kbd sending stuff on different channels....
				Jah Servant
everything is in polyphonic mode and the midi channel is set, I just can't get it to play only one note once I set more than one voice, always the extra voices will play
Hi
Like last module must be use poly out module - see example patch.
Remember - effect is not polyphonic not use this before poly out module !
Kamil
Kamil
				- polyexa.zip
- (389.25 KiB) Downloaded 199 times
				Jah Servant
thanks, it is something with the patch.  I tried a different patch and it works fine, so I'll just have to hunt down the culprit
				Jah Servant
ok, stupid mistake   , I had the vca and the poly out in the wrong order.  Strange effect it had though, try it, you'll see what  I mean.  Thanks for the help.
