G.O.S.T. DSP Plug-Ins
Hello,
there are some new devices available.
See : http://www.sonic-core.net/en/products/gost.html
cheers
ralf
cheers
ralf
Thanks a lot ralf!
now its official;
as i posted already a few pics on another thread may i just add the link to it:
http://www.planetz.com/forums/viewtopic.php?t=25447
plugs run on old HW!
with xite (we are all waiting for) dynomic should work at 96kHz SR too;
good vibes
now its official;
good vibes
tgstgs wrote:Thanks a lot ralf!
now its official;
good vibes
of course:stardust wrote:Looks interesting. Is there a manual to learn about the capabilities ?
http://www.sonic-core.net/documents/gost-dynomic-de.pdf
http://www.sonic-core.net/documents/gost-saw-de.pdf
-greetings, markus-
ps: yes, it's german. just for you. everybody else get these:
http://www.sonic-core.net/documents/gost-dynomic-en.pdf
http://www.sonic-core.net/documents/gost-saw-en.pdf
Re: G.O.S.T. DSP Plug-Ins
It sounds nice.
Re: Re:
well, Ralf can't care for everything, can he?stardust wrote:Thats servicekylie wrote:
Thank you Markus.
The technoloop treatment sounded impressive!
However, is there a technical reason for the Windows limitation?
I bet it is not a problem with just the few fossils still using OS9, but what about the upcoming OSX?
andy
the lunatics are in the hall
see:
http://www.planetz.com/forums/viewtopic ... a&start=20
osx:
lets see what we can do when xite is out;
good vibes
osx:
good vibes
May I please trouble one of you for an oscilloscope snapshot of Saw in use?
edit, typo
edit, typo
Yours,
Niall.
Niall.
what source do you want?
hier you have some pic of a 440Hz sinus -3dB;
http://www.planetz.com/forums/viewtopic ... 47&start=0
good vibes
good vibes
Thanks! Nice looking shaping going on there. All my CW stuff is back in the US, so I can't check anything out for myself. I look forward to hearing it.tgstgs wrote:what source do you want?
good vibes
Yours,
Niall.
Niall.
i get different translations;
if its the case of meaning->
there is no waveshaper inside!
you would not get this results with it!
saw cuts the wave with 0 sample latency on a sync sample value;
to choose the threshold and angle of cutting gives you the possibility to add the harmonics you like;
this is new tech!
at least i never heared of it before;
with saws in the insertslots of dynomic you are able to build you own response curve;
decide what harmonics you let pass and what you want to cut in which way;
hint: detune dynomic bands a bit!
no HW or SW driver is as flexible;
if you miss 'the other feature' of your HW tube driver -> turn on the noise!
good vibes
this is new tech!
good vibes
How about some presets as starting points?
/dave
/dave
we have designed the range response that you get 'fast results';
the default loading values should give you a good starting point independet of source;
but all further is haevy depending on the source you feed, your taste and what you want to get out of it;
specialy if its a guitar pluged in im sure you will love it;
but we use it also on snaredrum for expl. to make it more rough and add a bit high frequency harmonics without audible going in distortion;
sawed vibes from vienna
