I want known is possibile use for scope xite one host pciE card 16 x
in other word is posiible have how pcie host card one pciE 16 x in my pc?
I have only 16x and 4 x PciE slot in my MB,
wich tipe of host controller pciE have the new xite card?
sorry for my english
thnx in advantage
scope xite host card
- kylie
- Rank-o-phile
...but most consumer boards are equipped with pcie x16 (one or more) and pcie-x1 only (apart from old pci).stardust wrote:It hasn't been published yet.
But the PCI-E slots are downward compatible from the specs.
So you can use 4x card in a 8x or 16x slot.
that would mean if they make the card > x1 and you have a gfx card with peg (pcie-x16) you'll need a board with at least 2 peg slots.
if it is a pcie-x1 card (that is my guess, but then, it's just a guess) most boards available currently will fit.
since an express card implies a single lane, and express card is said to be the other type of possible connection for a XITE, the pcie card is likely to be x1, too.
http://www.expresscard.org/web/site/about.jsp
-greetings, markus-
Warp69
- hifiboom
- kylie
- Rank-o-phile
won't work.stardust wrote:my tip x4 and runs also on x1
I finally found what I was looking for:
http://www.redbooks.ibm.com/abstracts/tips0456.html
smaller cards in bigger slots are supported, but not the other way round. the cards are just keyed in a way they won't even fit mechanically. see also
http://en.wikipedia.org/wiki/Image:PCIExpress.jpg
a x4 card would have to have another notch to fit into a x1 slot.
-greetings, markus-
Shayne White
Here's an idea: maybe XITE can plug into either a x1 card or a x4 card (if you need more bandwidth). Since we don't know anything about it yet, let's hope that's true.
Melodious Synth Radio
http://www.binary-sea.com
