VST Host's Get Their Boost
http://www.anandtech.com/cpuchipsets/in ... spx?i=3326
Super re designed cache usage for multi threaded apps.
_____________________________________________________________
And this is a great chipset that has proven to work very well w/ 64bit apps using 8GB's of DDRII RAM. I really like this idea,
http://www.anandtech.com/cpuchipsets/in ... spx?i=3325
Neutron
Post by Neutron »
yay a new socket!
I sure hope they got rid of those plastic push pin things for mounting heat sinks, i hate them :P
yes.
Tau
Post by Tau »
Neutron wrote:yay a new socket!
Apparently, this won't happen:
"The socket is noticeably bigger than LGA-775 as is the mounting area for heatsinks. You can't reuse LGA-775 heatsinks and instead must use a heatsink with mounting holes more spread apart. As far as we can tell, the same push-pin mounting mechanism from LGA-775 is present in Nehalem which is disappointing."
