PaCo is a parallel compressor, the dry signal passes straight thru and the wet signal goes to the compressor. There attenuation for dry and wet and mute for each as well, so you can set your compression the way you want it then mix it in.
thanks to Shroomz for the knobs
enjoy
PaCo
Jah Servant
PaCo
Lima
chriskorff
