the demo records 12 notes with max 32 velocity layers per note. You can automaticly record up to 64 presets at a time.
So what I did was load scope in 96khz, load asio2 32bit drivers and started sampling.
These last two days I sampled about 30GB worth of 96khz 24bit scope synths!!!
I still mix them at 44khz. But somehow using the 96khz/24bit recorded samples sounds better.
I still have plenty of default presets I can sample. I'll just do that when I leave for work in the morning, then when I come home there are several GB's of new virtual instruments to play with.
The next thing I will try is combining 3 synths + effects + modulation. Then record them as one virtual instrument. I will add extra effects which get modulated by the velocity & notes.... then I will add about 8 velocity layers per note....... play the 3 synths in 6 voice unision (thanks alfonso) and record all that........ of course this has to be done at 44khz because my cards wotn load so much with 96khz.
Take special care in setting up your samplit projects. Once you start switching the asio & sample rate settings things can crash. Its important the samplit project you load is already "compatible" with the scope project running.
Good luck
http://www.cdxtract.com/samplit.php
