i got a second hand Pro-12, really nice one. did the system update without any problems. I'm working on Mac OS X, also no problem with the software, although sometimes the software doesn't show all correct values of the knobs.
ok, nice one as I said before.
But one thing I don't understand. A sound can be unisono or not unisono. as I learned before unisono always means "all voices together" and only one key at a time. So I would thing if I switch a pad sound to unisono I can only play one key at a time.
so why are they unisono sounds with only "one key at a time" and unisono sounds with them i still can play accords (more than one key at a time)??
am i missing something special with the parameters in the software?
question about the Pro-12 - unisono
virtualant
You got 3 pages in the editor, 1 for the main layout just as the ASB unit. 2nd page for additional settings like retrig, efx and Unsion settings
You can choose between 2-12 voice and a global detune between the voices.
When you select for instance 3 voices, then you can still play 4 notes at a time. You must have retrigger envelopes set to on and the Unison switch engaged and set the unit to polyphonic operation also ofc.
