output preload
nunziata
output preload
Post by nunziata »
hello, in the scope setting device in Device Manager
There is a Tools output preload
small or big
what does it mean
Lima
Post by Lima »
Hello, could you put a screenshot of what you're referring to?
nunziata
sorry
Post by nunziata »
in the pc DAW no inernet
however
controller audio video e giochi
setting scope
small or big ( output preload)
thank
nunziata
here picture
Post by nunziata »
hello
output preload small o big.rar
(28.55 KiB) Downloaded 307 times
Fede
Post by Fede »
Hi, it should be the setting for WAVE audio driver buffer length/latency, you may experiment with this setting in order to have much/less latency when playing back audio coming from scope and going to a media player or other wave audio application (Soundforge, wavelab...).
Wave Audio (Windows audio driver) has a big latency, about 300ms, so usually this setting isn't much useful, because for "real-time" audio the ASIO driver is commonly used. Wave audio is usually used for normal audio playback or for recording (bouncing) into an external program like a wave editor, all cases in which latency isn't important.
cheers
Fede
P.S.: so che è in un posto imboscato però nel manuale c'è spiegato abbastanza bene sta cosa :)
Lima
Post by Lima »
Hello, I don't know exaclty but it seems a kind of buffer to me. Maybe if you set up several wave source/dest is advisable to set bigger ouput preloads.
I'll try to find more informations :-)
the19thbear
Re: output preload
Post by the19thbear »
edit
ray
Re: output preload
Post by ray »
hello
Please can anyone resolve me this problem
I can't see the AUX PADS In BUS PAGE in Scope 4.5
They Are Hidden so How to View Them.
Guide Me
Cheers
