Where install scope,
Nuendo effects and VST?
Step by step
Thanks,
hello, step by step istallation scope and nuendo
nunziata
- FrancisHarmany
Re: hello, step by step istallation scope and nuendo
Just install in default locations! Maybe install neundo firstnunziata wrote:Where install scope,
Step by step
Thanks,
so scope can find the correct VST folder.
- the19thbear
are you talking about xtc mode?
if you are:
look at :
http://www.planetz.com/forums/viewtopic ... =gonzo+xtc
and
http://www.planetz.com/phpBB2/viewtopic ... =xtc+gonzo
here is my explanation:
( in the following text substitute cubase with nuende)
I dont know what you have and havent done, but this is what you need to do if i remember right:
1:Install scope with xtc mode.
2: create a folder inside your scope directory called XTC PLUGINS ( you decide) EG: C:/scope 4.5/devices/xtc plugins
3. open up the xtc configuration file in a text editor ( I think its called "vst config" and its located in some sub sub folder.. sorry about this but i cant remember, maybe someone else can help with the actual file name)
- In this file you should se a row of directories. One with the words mono in front of it and one with the words stereo in front of it.
Copy these two ( mono and stereo) text lines, and insert them in the bottom, right after the last line and edit them so they contain the path of your xtc folder.
EG:
ScopeMono C:/scope 4.5/devices/xtc plugins/*.*
and Scopestereo C:/scope 4.5/devices/xtc plugins/*.*
( i think that this is the same wording that is used in the file)
4. Go to your shared vst plugin folder, and pick a plugin that you know is working.( any plugin. not a creamware one) and copy that into your XTC folder EG:
C:/cubase/vst plugins/XTC
make as many copies as you need XTC plugins.
Now rename every single one of the copied plugins to match the names of the plugins in your C:/scope 4.5/devices/XTC plugins/ folder. but leave the DLL extension
example:
was supercomp.dll now renamed to minimax.dll
was supercomp.dll(2) now renamed to masterverb.dll
etc etc..
the actual dll files in your c:/cubase/vst plugins/ folder are actually not used at all.. they are just "shadows" of the files from the c:/scope 4.5/devices/xtc plugins/ -folder
5. edit the xtcproject located in some other sub folder to suit your needs. save it.
6.start cubase
Open the vst plugin menu in cubase and add the c:/cubase/vst plugins-folder as your shared vst folder, and restart cubase.
IF that doestn work, rename the vst plugins folder to something else, set it up in cubase and restart cubase again.
I know this seems like an awful lot, but when you get the hang of it, it is actually really easy..
if you are:
look at :
and
EG:
example:
etc etc..
6.start cubase
