Scope Menu Messed Up - How to Fix
Scotty
Post by Scotty »
Hi Guys, the scope menu across the top which lists asio, ios, plug-ins etc seems to be pointing to the root level of the c drive as the menu refers to the wrong folders. IS there a setting to point it to the appropriate scope folder somewhere?
dont have scope machine next to me, but check on your cset.ini...
pling
Post by pling »
in the settings menue there is a tab called 'directories'. seems like something got messed up there. you'll need a restart of scope to see changes.
the easiest way is to run the installer over the top of the old install. that should put the directories back into place.....
Scotty
Post by Scotty »
Thanks for the suggestion, if I reinstall over the directory does it replace the preset and devices?
Scotty
Post by Scotty »
Well I found the easy fix, I went into the SET menu,/ Settings / Dierctories: dragged the devices folder to the devices field and it set the appropriate path, Quit scope , restarted and everything is fine, 5 second fix.
