how i can change irq ?
nunziata
Post by nunziata »
How can I change irq?
I have the sound card on 21
and 1394 device on 21
How can I fix this?
move the card to another slot or shut down the firewire.
another option is to reinstall windows in standard pc. however, depending on the physical architecture of the motherboard, you may STILL get sharing. if you must have the card in that slot AND you really need firewire, then get a pci-e firewire card and disable the built in 1394....
cemhot
Post by cemhot »
I like to join this.
im installing my new system, and its the irq 18 (usb) which is shared with my card in the 3rd slot of my Gigabyte Ds3R.
This bios contains also a menu of irq settings auto/manual.
I tried those, but it behaves like ever since - that it doesnt take an effect.
Now i swapped it to the other slots and if i take the first one, which is of course
near to the grafics i get irq 20, which is not shared.
i would have to install some music apps to test if the grafics has any effect on the sound.
do you have any experience with nowadays grafics, if they cause interfering sound?
I guess you would say i have to test....?
The other possibilitiy is to switch off some of that usbs, the ones on irq 18
I would still have 2 in the back and two in the front as i tested.
Funny side effect:
Thwo of these usb ports (that i disabled) behave like usb 1.0.
What would you do?
Would it make a difference if i take out all possible components when doing a fresh install?
i´d like to stay with ACPI.
Thank you!
Neutron
Post by Neutron »
what if you have some synths and effects with usb interfaces for vst control, patch editing etc. way too much of my stuff has USB to put it through hubs.
cemhot
Post by cemhot »
stardust wrote:i would switch of the USB controller that shares the slot.
alright, i needed that opinion. If someone else tells me it seems very reasonable.
Thank you!
nunziata
absurd
Post by nunziata »
absurd.
I managed to make it work but (thinking the wrong way)
Presonus digimax Master
World clock distributes to other devices Slave
A16 ultra Slave
scope Slave
Roland Slave.
So 'work but in the samplerate project is set to master.
So strange but true 'not me dropout problems, I have not yet tried but' to record mic with zlink source.
if set slave scope in this configuration compare this message """"division by zero""""
Stuff crazy.
IRQ 0 Timer di sistema OK
IRQ 6 Controller disco floppy standard OK
IRQ 8 Orologio di sistema CMOS a tempo reale OK
IRQ 9 Sistema compatibile ACPI Microsoft OK
IRQ 9 Controller host SCSI/RAID OK
IRQ 13 Coprocessore matematico OK
IRQ 14 Canale primario IDE OK
IRQ 15 Canale secondario IDE OK
IRQ 16 Intel(R) 975X PCI Express Root Port – 277D OK
IRQ 16 Radeon X1300 Series OK
IRQ 16 Intel(R) 82801G (ICH7 Family) PCI Express Root Port - 27D0 OK
IRQ 17 Intel(R) 82801GR/GH/GHM (ICH7 Family) PCI Express Root Port - 27E2 OK
IRQ 17 JMicron JMB36X Controller OK
IRQ 17 Intel(R) 82801G (ICH7 Family) USB Universal Host Controller - 27C9 OK
IRQ 18 Controller standard PCI IDE OK
IRQ 20 Intel(R) 82801G (ICH7 Family) USB Universal Host Controller - 27C8 OK
IRQ 20 Intel(R) 82801G (ICH7 Family) USB2 Enhanced Host Controller - 27CC OK
IRQ 20 Adaptec ASC-39320 HostRAID driver OK
IRQ 21 Creamware Scope OK
IRQ 23 Adaptec ASC-39320 HostRAID driver OK
IRQ 23 Intel(R) 82801GR/GH SATA AHCI Controller OK
Neutron
Post by Neutron »
stardust wrote:Right but ussually they can be bundled via an external hub to a single controler/USB slot if they are not using full bandwidth of USB 2.0.
i guess if wort comes to worst, i could get PCI-E usb controller.
Neutron
Post by Neutron »
stardust wrote:My cubase and reaktor 3 USB dongle are connected to the same USB port and I never got performance issues with that.
thats not a lot of data.. hi dongle 3234655367 are you there? yes im here!
something like virus desktop TI would probably stress it slightly more
usb2.0 handles a fair amount of data. most current motherboards have 6 or more usb controllers and 2-4 usb2.0 controllers. you can afford to disable quite a few before you will have a problem, or even before you find usb ports not working....
i've had a midi controller, dongle, memorystick and cd burner on a hub with no issues. the virus could still have it's own port, only 1 usb2.0 controller and 1 or 2 usb controllers would be required. a mouse and keyboard could likely be in the mix too, but one more usb controller would seal the deal.
husker
Post by husker »
don't forget with a USB 2.0 port connected to a USB 2.0 hub - if ANY of the devices plugged into the hub are running at USB 1.1 speeds, then ALL the devices will then be forced to run at USB 1.1 speeds - a single port can't mix and match speeds
which is the reason why each port on a motherboard is actually and independent USB controller
no, there are only a couple of 2.0 controllers and they handle several ports. the usb controllers handle any, all or none of the ports. there are usually more ports than controllers.
Polarity
changing XP mode
Post by Polarity »
I think I've some problems with my two Pulsar cards on the new DAW with DFI Infinity dark-S Motherboard and a Q6600 CPU.
The same problems due to IRQ sharings as I had on previous DAW in ACPI mode (resolved passing to PC Standard Mode).
I didn't make till now to change IRQ and impose a private one for the two Pulsars.
So, I was wandering about different Win XP modes:
PC standard: does a Multicore CPU still work as it should iunder this mode?
MPS Multiprocessor: What's this mode? Similar to ACPI Multiprocessor.. but NOT ACPI and more similar to Standard PC (but Multicore support). Or is for physical multi processor on boards, as for XEON CPU's??
I tried to convert my actual Win XP config to those two modes, but after initial conversion, the system didn't make to restart at following reboot. Don't know what went wrong.
(So I used my backup to rebuild in a few minutes the previous working OS).
Before trying to install them from scratch I would like to know if they work with a Q6600 multicore CPU aa in ACPI mode.
Any here know the answer?
I didn't find this clue searching around on net...
Thanks a thousand in advance!
