This is what I could achieve investing 2 hours of work in an emulation (measuring & building) of the high-band boost/att of a wellknown Equalizer.
The center positions of the freqshifters are at 10khz for att & 8khz for boost.
I captured the max positions for att & boost @ broad sound & some lower position for sharp sound @ boost.
This EQ is quite complemetary to TziTzi
Have fun
Martin
EDIT:
+ 1 hour adjustments. Even closer to the originnall unniversall Pulenc.
UNÜtek EQ 02
UNÜtek EQ 02
- UNÜtek.zip
- (1.2 MiB) Downloaded 562 times
- Mr Arkadin
It's a dynamic control over 'too much' high. There is an additional panel hidden inside which would allow more control, but these devices are kept simple
Maybe I forgot a diode - so the dyn button shoots the default value to the knob when hitting it which was truly not intended - but it should be no real problem, or is it?
- cannonball
